foehnsturm 969
You may want to have different test pieces for different materials?
This may be a good entry point for two colors, but you would want something completely different for PVA.
And again something different for a combination with flexible materials.
Yes and no. Of course you want to have test pieces for special application areas. These will bring up a lot of additional issues caused by the varying filament properties.
This piece is intended as kind of an entry test which mostly focuses on the dual extrusion hardware. In other words, how clean (the result) and smooth (user friendliness) can a dual extrusion setup perform if part geometry is the only challenge.
SandervG 1,518
