well ill try that tonight... yesterday was late in the night and without wanting it, by leveling the plate it came in contact with the nozzle, moving the printhead a Little bit up... i hope the rods are ok... was weird, because i was moving the build plate down (by turning the dial to the left)... but suddenly it started moving up instead of down, thats why the glass crashed with the printhead. you think that was enough to bend the rods?
If you want to check it's pretty easy to take out the xy rods, and roll them on a flat surface to check....
If you need instructions you can use the upgrade kid manual;
https://ultimaker.com/en/resources/19641-installing-the-extrusion-upgrade-kit
DidierKlein 729
Maybe you need to relevel your bed but first retighten all the leveling screws before doing it?
