How does the slicer work?
mokash770
Posted · How does the slicer work?
Hi, I am trying to make the Z command get resent to the printer with the GCode generated after the custom GCode is run when switching extruder heads. However, I am having difficulty locating the code that accepts the custom commands in the sidebar. If you know where it is located in the source code that would be a great help.
Thanks in advance!
    You should not modify cura but instead use a cura plugin. Look at the source code for "tweak at z" to start out - you can use some of this code and then modify it.
        • 24 replies
