DidierKlein 730
Yes indeed use pause.
With the UM2+ feeder i find it difficult to push one piece of filament with another one.
The easiest way to go is to remove the filament and put a new spool.
If you use the change material procedure, i found out (the hard way) that the priming isn't good enough when you resume the print so i would advise to release the tension in the feeder with the lever and push your filament until it comes out properly.
Then resume the print
ultiarjan 1,223
Use pauze. Load new fillament....
And maybe try it once before it happens on a 30hr print
