There is no need to make complicated changes the tinker firmware is readily available for the um2+
I know, but I wanted to keep my settings as the + version increments the eeprom data version and you have to go through the bed levelling again and I wanted to avoid that. "Change a running system as little as possible."
But I fixed it...
...tuns out my SD card failed a bit. Only a bit because it works as normal but sometimes when reading it reads just garbage -> so some gcodes were read wrong which resulted in weird movements.
Edited by Guest-
1
ultiarjan 1,220
I can't explain. But first thing I would do is a factory reset and reinstall the firmware again.
