Underextrusion at low speed but perfect at high?
Lobopt
Posted · Underextrusion at low speed but perfect at high?
Hi have a strange problem , i have heavy underextrusion on my 2 go when i print at 0.1 with 30 mm/s but perfect prints resolution wise at 0.2 with 60 mm/s at same temperature.
I dont really understand since normally it should be the other way.
    You tried with a lower temperature ? 190 - 200
    Oh yes much much worse then but only at low speed what baffles me a bit.
    Really strange....
    Nozzle size and fan % ?
    Really strange....
    Standard 0.4 and gradually increasing fan speed 0 at stArt 30 at 5 layers 60 at 80 layers and 100 at 120 layers worked well for 2 months . Btw at 0.2 layers are half of 0.1 . Always verifying the temp curve so it only moves up and down about 3 degrees c in any way
    Really strange....
    Ok found out it was simply too slow for that part the head dragged it around.
    C etait trop lent la tete a tire la piece dans tous les sens.
