printed model not solid.
tmtan
Posted · printed model not solid.
All,
Recently, all my printed models not solid and the outer layer can be peel off easily.
I'm using PLA and my setting are below.
Layer Height = 0.2mm
Shell thickness = 0.8mm
Bottom thickness = 0.4mm
Fill Density = 100%
Infill overlay = 20%
Print speed = 70mm/s
Kindly help. thanks.
regards,
TM
    That sounds like 'underextrusion'. Basically you might need to use higher temp.
    Anyhow knowing what causes it, and there's a gazillion different thinks that can cause this, from the settings to the machine itself. You need give much more details.
    - Temp
    - Full range of settings
    - Machine and model used
    - Lifetime of the machine?. Did it print like this before?, it's this the first print?, it's a complex model?
    More data much more data. And specially a photo of the print.
        • 28 replies
