That sounds like 'underextrusion'. Basically you might need to use higher temp.
Anyhow knowing what causes it, and there's a gazillion different thinks that can cause this, from the settings to the machine itself. You need give much more details.
- Temp
- Full range of settings
- Machine and model used
- Lifetime of the machine?. Did it print like this before?, it's this the first print?, it's a complex model?
More data much more data. And specially a photo of the print.
neotko 1,417
- Temp
