Weird behaviour with multiples instance of "pause at height" plugin
Posted
· Weird behaviour with multiples instance of "pause at height" plugin
That problem I had too recently. Solution is: You have to define the stops in reverse order! first instance pause at 1,4mm, second instance pause at 0,8mm. I don't remember where I found that info, it was somewhere documented. Anyway, after that change, everything worked fine for me.
avogra 68
Eurotronic 2
Thak you very much for the tip avogra!
It came out perfectly.![:D](//content.invisioncic.com/ultimake/emoticons/5a33abe7dfbbe_1f600copy.png)
