Ultimaker Original Plus assembly .STEP file ?
Posted · Ultimaker Original Plus assembly .STEP file ?
Hi
I recently bought a second hand Ultimaker Original Plus which i am in the process of upgrading to a use the UM2+ upgrade kits plastic parts, with dual E3D V6 nozzles. and UM2 Sliding blocks.
I have looked on Github which has all of the individual part STEP files however no full assembly.
Does anyone have a full assembly step file for a UMO+
Would be much appreciated and make my life much easier.
Thanks
Moses.
    Ultimaker never released it. Use the umo step file (it's on the um2 github...) and download the frame dxf. Mix that with the bed of um2. I did that to have an accurate model of umo+ for my mods.
    Thanks mate, I didn"t realise it was tucked away in the ultimaker 2 folder
    same question here - has anyone created a full (3D-CAD) assembly of UMO+ (Step file)?
    I'm not familiar with github and it seems not possible to upload files here, so i opened an issue concerning the missing assemblies in github. In the post you find a link to the assembly of the printer head.
    It's not perfect, the 2x M3x4 screws are missing but for investigations/redesigning it should be ok.
    https://github.com/Ultimaker/Ultimaker-Original-Plus/issues/3
