Cura G-code Feedrates
stonethrow
Posted · Cura G-code Feedrates
Can anyone explain how the G-code extrusion feedrates are calculated in Cura? How does the actual material extrusion rate (mm/sec) correlate to the G-code generated feed (for example F1200.0)?
What variable in Cura changes the extrusion feedrate?
Thanks in advance.
    • 3 months later...
    I just stumbled over your three months old post, which isn't answered yet.
    Since I'm now dealing with the same issue: have you succeeded to get the info on different ways meanwhile?
    Best, Peter
    AFAIK, the values in the g-code are still in mm/min, for historic reasons, and now there are too many machines to change it. divide it my 60, and you'll see the mm/sec
