UM2 hotend 9.4mm & 8.4mm adjustable spacer
Posted (edited) · UM2 hotend 9.4mm & 8.4mm adjustable spacer
It's untested because I have a long weekend ahead. But it should just work. It has two positions 8.4mm distance and the other 9.4mm distance. I printed it on PLA-tec. Also on 9.4mm distance you can see through if the Bowden it's on.
https://www.youmagine.com/designs/ultimaker-2-9-4-8-4mm-spacer
Printed on black PLA-tec (110-120 heat resistant) using window cleaner + 1 hairspray puff before heating the bed for adhesion. 0.1 layers 50mm/s fans full at layer 30ish.
    Posted · UM2 hotend 9.4mm & 8.4mm adjustable spacer
    If you use the i2k 1mm you need a different spacer if you want to keep the nozzle on the same height/not touching the metalfancap.
    Also if you play with the coupler or want to use two different heights (dual?) without using a spring, then this helps (not my design but the one from anders).
        • 6 replies
