holes in the model
tinushigh
Posted (edited) · holes in the model
Dear Ultimakers,
I am printing an object with a little hole in it because a temperature sensor will be put into it when the project is finished. Using the Solid view I can see the hole, 2016-06-13.thumb.png.7b7983305d9b70109286d1857cb3862a.png
using the layers view I can't see the hole and when printing my UM2 doesn't print a hole.
does anyone know what I'm doing wrong?
Thanks in advance!
Martijn
    • 2 weeks later...
    Posted · holes in the model
    Dear Martijn,
    Did you draw the model yourself? In Cura you can use the X-ray button to see if your model has been drawn correct. A purple colour indicates a problem. It might be, in this case, that the model is not proper closed, has empty spaces, so the printer does not understand the data properly. If I am correct with this, and you see indeed purple parts in X-ray view, then you should need to fix it in the model itself. Although sometimes the cura setting >expert - fix horrible might help you out as well.
        • 30 replies
