Posted (edited) · Cura Black screen and objects
Can someone please help me.  I have installed and re-installed cura on my mac book for my BNC3D Sigma and am having major problems. First when I loaded a model it showed as solid black on the bill plate, but, if I move it slightly off the build plate it appears normal.  I tried going to low resolution but nothing changed.  Now when I open Cura I get a full black screen .. I using OS X El Captain.
How do you totally remove every trace of cure.
Thank you
    • 1 month later...
    Posted · Cura Black screen and objects
    Hi, I've been struggling with the black screen issue too and have no response or solution to that.
    I've tried to run Cura 15.04.5 and 15.04.6 with no success. I read in other forums that the problem might be the GPU, but the funny thing is that Cura runs with no problem in another one with same specs.
    I have an Asus TP500L i7 with 8gb of ram and Nvidia GeForce  940m.
    Is there a way to fix this?
    Thanks
