Cura 2.1.2 -- how to change a removable drive?
2go
Posted · Cura 2.1.2 -- how to change a removable drive?
This is minor inconvenience, but...
Running 2.1.2 on iMac. Clicking 'save to removable drive' saves gcode file not to SD card but on one of my external USB hard drives. Is there an option to change this? Previous Cura versions saved directly to the card inserted in iMac's internal SD slot.
    • 2 months later...
    When I click save to removable drive, my software does nothing.... help!! please??
    I get an empty box on the bottom of the screen with an "X" in the upper right corner
    2.1.2 on a MAC with a Malyan M180
    I've seen that when I've used corrupted SD Card or it is 'locked' (there's a stupid switch on the side of full-size SD cards that can lock them from being written to)
    Check to make sure your SD card/USB Drive is not corrupt and is not locked.
