It may be that cura won't be able to connect until you fix the MAXTEMP problem.
Thanks gr5 (nice logo)
You are right. When I remove the connector of the thermocouple. The display says Ultimaker ready. And I am able to connect to the computer also.
I measured the output voltage of the sensor and it was 0V (in fact much less than 200mV) and remains that when it is getting warmer. So I think I have to replace that. I already removed it from the heater block (that wasn't easy). Now I wil try to find a new one.
Thanks for helping.
kind regards,
Johan
However, the problem can have more causes:
1) the thermocouple
2) the small thermo interface board
3) the connection with the board
When I disconnect the thermocouple from the board it says Maxtemp
When I disconnect the connection betweer the thermo interface board and the Ramps board it says that everything is OK.
How can I check the interface board?
OK that last one was a good idea: the connection. Why didn't I check that before? It appeared that as well the black and the brown wire are broken. When I connect them there is something new on the board: a blue light! Yes and a temperature of 19 degrees (Celsius)
1
gr5 2,224
You have a display. That's great. That means you don't have to print through USB (which is more difficult).
MAXTEMP is probably the most serious issue here. Something is wrong with the temp sensor. There should be a green terminal connector on top of the print head that has 2 screws and 2 wires going to it. Check that the wires aren't loose. The temp sensor is a bit complicated - there is a thermocouple inside the print head. The 2 wires for that go up to the tiny circuit board on the print head and get converted to a voltage. I hope you are good with electric circuits or there is someone you know who can fix very simple circuits. The output voltage of this tiny board is 0V to 5V where 0V=0C and 5V = 500C and linear in between. So at room temperature it should be about 200mv.
If that is at the correct voltage then it probably is not connected properly on the circuit board underneath the printer.
