Labern 774
The old um2 pt100 weren't always very accurate. I had one that was 20deg out and had similar problems like you.
Replaced it and it was all good after that.
This is why the um2+ has an improved pt100 that is a lot more accurate.
If yours is intermittent then it may due to a loose wire, broken wire or the pt100 could be damaged inside.
