Using 15.04.3 version of cura- how do i start a print?
Posted
· Using 15.04.3 version of cura- how do i start a print?
Get pronterface/printrun and install it. Connect your computer to the printer through USB. This software allows you to be very careful - for example you can move X axis by 1mm and makes sure nothing bad happens without having to home it. You can then move it 10mm and see if steps/mm is correct and also edit these settings and save them from pronterface. You can also test your limit switches and then test homeing procedure. All one axis at a time. Then test temperature and heater.
I forget where you get it as I am travelling this week but if you google pronterface and gr5 at site:ultimaker.com you should be able to find it.
gr5 2,192
