Currently, it is set to 3 minutes.
Why would that setting only affect larger prints and not smaller ones?
My suspicion is that this happens, if the command buffer runs empty. And the probability for this is much higher on longer prints with many (and small) line segments.
tinkergnome 929
It's probably related to the "heater timeout" in the firmware. If you print via USB (like Octoprint does), you should disable it on the printer:
Advanced -> Preferences -> Heater Timeout
(reduce the value for "Timeout" until it shows "off")
