Just the simplest, rectilinear, but unfortunately this is on the old Cura engine 14.xxx
To add on to @nallath you also need to know your layer height to add to the cross section of the area.
nallath 1,125
Depends on the pattern as well.
Cura 2.1 also shows you the infill line distance. So if you set the infill at say 80, it tells you that the distance between infill lines is 0.625.
