Cura 2.1.2 crashes into object in "One at a Time" mode
znib
Posted · Cura 2.1.2 crashes into object in "One at a Time" mode
I moved from Cura 15.04.6 to 2.1.2 yesterday and tried to print two parts in "One at a Time" mode.
When it started to print the second part, the print head crashed into the first part because it placed the two objects two close to each other.
In 15.04.6 I can set the printer head size, but I can't find this setting in 2.1.2, can anyone tell me where to find it?
Also, when I have a Ultimaker original, with completely original printer head, and I choose "Ultimaker original" as my printer in Cura, why does it not have the correcet printer head size set already?
    Posted (edited) · Cura 2.1.2 crashes into object in "One at a Time" mode
    It could be that we made a mistake with the sizes. I've created a bug report on our internal tracker for you.
    You can change the head size in the ultimaker_original.json file. The setting you are looking for is called something like machine_head_polygon.
    My guess is that this went wrong because we actually hardly have un-modded UMO machines in the office (and never got tested quite right). Shame on us...
    *edit* : For our own reference; CURA-1948
    It's machine_head_with_fans_polygon.
    In Cura 15.04.6 it had the following numbers:
    Head size towards X min 75mm
    Head size towards Y min 18mm
    Head size towards X max 18mm
    Head size towards Y max 35mm
    However, all of them except X max seem to be very optimistic, I'd add at least 5mm to each.
    In ultimaker_original.json machine_head_with_fans_polygon I can see 8 numbers, grouped in pairs:
    -75, 35
    -75, -18
    18, 35
    18, -18
    So the numbers seem to be the same. I don't know if it crashed into the part because the numbers are too optimistic, or if there is a bug somewhere.
    Anyway, I think there should be a way to set the printer head size without having to edit a .json file. Even if it comes with correct defaults, many ppl have modified their print heads with other fans, etc.
    I think the order of the points in the polygon are wrong. Plotting those out, in the order given in the json file produces a bow-tie like object.
    I think the points should be in this order:
    -75,35
    -75,-18
    18,-18
    18,35
    -75,35
    -75,-18
    18,-18
    18,35
    I see what you mean. Unfortunately, I won't be able to try this until end of next week, maybe nallath can confirm that this could be the problem?
    I don't think it matters in what form the points are.
    Removing my reply. I didn't read nallath's comment correctly
