Posted · Easy One; Rod Slides Out
Hey all, the back (top) rod on my Ultimaker 2+ slid out to the left to the point that the right side fell out of it's mounting hole and the print head made a noise at one side of the print. The noise is what alerted me to it. I put the rod back into place and now it is slowly sliding out to the left again.
Is this a loose collar or both collars loose? My guess is the left one is loose. Thanks in advance.
Les
    Hi Les,
    Its a problem I had initially with my UM2, its caused by the collars/pulleys coming loose.
    you should center everything then tighten all small allen/hex screws on all pulleys
    should be a quick solution
    good luck
