just for clarity, as you say you are not 'electronic savvy' running in series means the current goes through one first and then the other
If you were to look inside the black block of the print head you would see this is how they are wired, if a connection breaks both fans will stop working
hope that is clearer - good luck
neotko 1,417
x2 12V fan in parallel on a 24V plug... Do you see the probem?
Run them in series so they actually use 12V on a 24V plug. Also, I might be wrong, but pluging 12V fans on a 24V can destroy them. So, test serial.
