Probably at an angle.
In this case is at an angle.
As you can see in the imagens, there is a lot of overlapping toolpath extrusion in only one layer, this will cause some problems in the shell of the prints, if I increase the print speeds.
I think if we could uncheck the zigzag extrusion, we could have better prints for higher speeds.
Edited by GuestThe zig zags that you are talking about are top/bottom layers. As the side wall is on an angle it lays a small section of a top or bottom layer in the area covering the amount of angle.
(Don't think I explained that well)
Labern 763
Is the wall vertical? Or on a angle?
