What type of filament are you using? I've issues with this happening with ABS. I set the print speed to around 70% and it solved the problem.
What settings are you running?
When i run into issues like that, the first thing I do is slow it down. I would also look at the filament if I saw something like that. It looks too hot or like over-extrusion. Make sure your nozzle isn't worn or your nozzle size is set wrong...I've changed nozzles to a .25 and gone screwy when I sat down at the computer and sliced for a .8mm nozzle before.
I'd really look at the filament, though. Did this just start recently?
Your pics are kinda fuzzy, but if I knew my nozzle and filament were good, I'd slow my print speed first, then start looking at other settings depending on what you're running.
Yuviten 0
