Cura and first layer
drindt
Posted · Cura and first layer
Hello Forum,
i am using cura 2.1.2 and have an issue by printing this camera mount http://www.thingiverse.com/thing:1704892. The base plate with the hole in the mid must be 1.6mm in height. But after printing it is 1.7mm. It seems that cura adds the thickness of the first layer plus wall thickness top and bottom.
What i should do to achieve the real size from the stl file in the printer?
Thank you a lot for reading.
Daniel
    I'm thinking you're printing at .2mm Layer Height and .3mm Initial Layer Height.
    This tends to offset the layers by .1mm accounting for the runover from 1.6mm to 1.7mm.
    Two things to try:
    1. Print at .1mm layer height (better quality prints, but twice the print time)
    2. Set .2mm Initial Layer Height. You may have issues getting the prints to stick to the bed pending on your printer, filamant, bed adhesion type...
