Posted · Stop print warping.
To prevent print warping use PrintBite from 3DFilaprint.
since using this addintion to the print plate I have not had any warped prints.
No glue is needed, even for ABS.
As long as the base plate is hot (100 Deg) the print will stick
once cool the print releases cleanly.
I am using the raft with a 5/8 mm margin for platform adhesion.
Phil Sharrock.
    • 5 weeks later...
    One more thing, you still need to clean the build plate with acetone on a regular basis,
    say after 10 prints or if you see the print lifting.
    Wipe with kitchen towel wet with acetone and then wipe with a dry kitchen towel.
    this should restore the printbite.
    Phil
