tinkergnome 917
Out of curiosity, do you think that if I downgraded to an earlier stock version before the address changes, then put in the old Tinker 16.07 that I could get back to what I had before?
Downgrading without a factory reset will not restore any settings in EEPROM - and not all settings can be changed with gcodes or the printers menu - no luck.
tinkergnome 917
It's probably not motor current or steps, that would affect the standard firmware too.
My suspicion is the "printing area". Can you take a look at this? If in doubt - take pictures of the relevant screens.
The runtime statistics are preserved during a factory reset, but i would make a backup of the material profiles, if you've made customizations...
tinkergnome 917
Update:
Ultimaker has moved some settings in EEPROM to different addresses recently...
and that overwrites the "tinker" settings that are already stored there...
So... if you switch back and forth between the standard and the tinker variant... a factory reset is mandatory from now on... (at least for the + models)
krys 206
Hi @Tinkergnome. Thanks for responding.
I see. So, to upgrade I need a factory reset. Sad Panda! :(
Out of curiosity, do you think that if I downgraded to an earlier stock version before the address changes, then put in the old Tinker 16.07 that I could get back to what I had before? It was working fine for me.
I probably would not stay that way, stuck in time as it were, but I am just curious if you think I could go back in time by downgrading.
Thanks very much. And thanks for your firmware! I really like it!
