Painting on 3d printed Selfie
lprakash03
Posted · Painting on 3d printed Selfie
Hi @lprakash03,
Thank you for your message and welcome to the forums.
I'm not sure whether or not it is a selfie is important, but on what material you want to print.
Will it be printed on an Ultimaker?
What material will you use?
Generally speaking, adding a primer first before applying paint is a good idea. Both for surface smoothness and attachment of paint.
    Hi @lprakash03,
    hi SandervG,
    I am trying to print human face using 3d printer. i'm trying to print using ABS material.
    to give a realistic color to face, how can the painting be done>
        • 4 replies
