Curling comparison - Colorfabb XT vs Esun PETG
Melka
Posted · Curling comparison - Colorfabb XT vs Esun PETG
Hey,
I am quite disappointed with the Colorfabb XT filament, especially at this price point.
There is a lot of curling, especially on overhangs.
Strength-wise, I didn't feel any difference between XT and Esun PETG. It doesn't mean that there are not, simply that I didn't perform tests to actually measure it.
I should have tested the filament instead of relying on the spec sheet and marketing words on the official website before dropping 130 euros (4 rolls).
By the way, I contacted Colorfabb's support and they replied:
The results you have achieved with our _XT material are in line with what I would expect to see for such a model.
So yes, I would say this is an expected result.
It does seem indeed that eSun's PETG handles the dissipation of the heat better in this case.
Until somebody compare the properties of Esun PETG vs Colorfabb XT, I would advise you to stick with Esun PETG. You'll get a much better finish.
  • 5 months later...
I get some curling on overhang corners using eSun PETG, but the fix is easy: slow down the speed to about 20 mm/s for a few layers (and drop the nozzle temp a few degrees).
I've gone through about 45 rolls of their PETG and I keep buying more. It's been consistently good quality for me, and the parts have been strong.
  • 2 weeks later...
We have not had this experience with warping of ColorFabb XT. To look for warping we use a 6cm x 6cm x 0.8cm (w x d x h ) model (warping is more likely to occur on wide low height models) and we have ended up with a very flat model.
This is not to say that warping will not effect particular models or print environments but it was quite straight forward to achieve this effect.
We cannot comment on the eSun PTEG so we cannot compare. we can only say this warping issue is not our experience.
The printing settings for this print are written on the file.
