tinkergnome 917
I don't see any correlation of this from the Gcode generated by CURA. Has anyone seen any example firmware code for controlling the Extruder Motor?
I'm not sure if i fully understand your question... but i think you're on the right track.
The generated gcode is only a request to move the axis along a line segment with the specified feedrate. And it's the task of the firmware to decide how to achieve this.
For Marlin firmware all the relevant calculations are done by the planner. There is also a separate documentation project with some basic informations.
Labern 772
there will be others who can share a lot more then me on how it all works but In the firmware there is a bowden tube length which is added into the mix.
there is also something which adjusts the extruder while accelerating and decelerating but i'm not sure if this is implemented.
You can adjust coasting before retracts in 2.XX cura though.
