Those chinese boards are so cheap and not very good quality so it's always best to buy 3.
I don't know if they have a different circuit but I strongly doubt it. more importantly did you load the right firmware onto the arduino on the 1.5.7? You may have loaded the UMO+ firmware by accident which expects a different voltage from the thermocouple. Also you might have to remove a 4.7K resistor possibly. Some of the temp measurement circuits use a 4.7K pull up resistor but I don't think you are supposed to use that for the UMO circuit.
Also if the extruder motor is fine and the driver is fine it's almost surely the arduino and not the PCB as there isn't much circuitry on the PCB itself. So did you get a new arduino with that new 1.5.7 board?
no, I didn't get a new arduino with it, just the 1.5.7 board.
I also haven't updated firmware on it, so it might have UMO+ on it instead of UMO. I will try that later today.
the extruder driver wasn't good, but replacing it on the old board didn't fix the issue. which is why I suspected the circuit board.
gr5 2,072
