I think the @tinkergnome firmware for all machines is all based on one source, so it would not surprise me if the UM2 version also has the new 115c limit (did not try it).
Regarding the correction for the geared feeder no need to correct using flow, if you use the tinkergnome firmware you can just set the e-steps and your done.
e steps UM2+ feeder with new feeder motor: 369
e steps UM2+ feeder with old UM2 motor : 738
e steps UM2 (old feeder) : don't know (my machines are upgraded) but if you have the UM2 you can just read it out in the tinkergnome firmware.
the hex files are the packed firmware, ready to install, use cura 15.xx and select install custom firmware. make sure to take the correct one for your machine.
ultiarjan 1,223
you'll find the firmware here;
https://github.com/TinkerGnome/Ultimaker2Marlin/releases
