*Facepalm* Thanks, nallath. Works like a charm.
Something I don't understand, if I am printing One at a time but I'm only printing one thing - why is the height limited since the height of the nozzle will never be higher or lower than the currently printed layer? But, thank you. That clears up a huge frustration here
nallath 1,065
You're printing one at a time. The distance from the nozzle tip to the axis is the max height at that point.
Try changing the print sequence setting to all at once.
