Cura 2.x User Folder for plugins
markwal
Posted · Cura 2.x User Folder for plugins
How about:
Windows: %AppData%/cura/plugins
Mac: ~/Library/Application Support/cura/plugins
Linux: ~/.cura/plugins
What do you think? I could do a PR unless there's a philosophical objection.
    I have no issues with that. I would suggest that only "user" plugins are placed there (eg; Not plugins that are defaults, as we tend to update them).
    We would also need a way to handle conflicts (what happens if translate tool is put in plugins folder)
    Ah. You're right. They do work. I attempted on Windows first and it didn't work (probably because I got the path wrong), but now I was debugging on Mac and yep, it's already in the _plugin_locations. So, never mind.
