Ungroup pieces from 1 .stl file in Cura 2.1 / dégrouper des pièces d'un meme fichier .stl dans Cura 2.1
Katpraline
Posted (edited) · Ungroup pieces from 1 .stl file in Cura 2.1 / dégrouper des pièces d'un meme fichier .stl dans Cura 2.1
I have 20 little pieces that I would like to print on a cardbord. Each has a specific place that's why they are in the same .stl file. Can someone tell me how to print each piece one after the other ( and not all in the same time)? I precise, I don't want to import each piece individually in cura as it will be impossible to put them in the right place and that you can only ungroup pieces from different .stl files.  ( modify/ungroup objects).
Do you know a way?
Thanks in advance for your help.
Edited by SandervG
    Posted · Ungroup pieces from 1 .stl file in Cura 2.1 / dégrouper des pièces d'un meme fichier .stl dans Cura 2.1
    We haven't ported this functionality to cura 2.x yet. It is possible if you save it to 3mf, as that actually supports multiple objects in a single file.
        • 27 replies
