Posted · Brass nozzle jammed after printing some bronze parts
I know brass is not the intended nozzle to print bronze. I printed only about 5 parts and then replaced it with a hardened steel nozzle.
However, when I tried to use again the brass nozzle (0.4mm) i have been unable to clean it up. No way. I tried atomic pull several times without success.
I can see the hole is closed with some remainings of bronze filament at the nozzle tip.
Any recommended way to recover this nozzle ? Perhaps using some higher temps or something ?
Luis.
    I always keep my dirty nozzles in a seperate place and we I got enough of them then I clean them with a butan torch.
    I hold the nozzle with a heat resistant pair of tweezers to not get burned. Make sure you put a heat resistant plate on the table you're going to do this or you'll destroy your table with nasty burn holes.
    Nozzles that I used for long prints with abrasive materials are going straight in the trash can because they are worn-out. :)
    fyi, a new nozzle costs 12 euros.
