extrusion amount depends on temperature and layer thickness
Posted
· extrusion amount depends on temperature and layer thickness
I my view, temperature should not influence the amount of plastic that is extruded.
Unfortunately, it depends a great deal on the temperature, or more precise, at the heating capacity of the hot end. the lower the temp the higher the viscosity, which is counter-balanced by low printing speed.
if you print faster (more mm^3/sec), you need a higher temp (as your data confirmed).
joergen 2
