Adding brim at the base (it's a cura option) will help it from coming off the bed completely but the wobble will decrease quality the higher you go. I recommend support that reaches half way up. In other words, add two towers maybe 2 or 3 cm away from the base in 2 different directions 90 degrees apart (say one towards the back of the printer and the other tower to the left side of the printer). Have those 2 towers meet the flagpole half way up - around 75mm up maybe or 100mm up. Once those towers meet up stability will be improved and you'll get at least another 100mm.
Later you can cut off where the towers touch the flagpole. Make the tower touch only on one square mm so there is little to cut off.
gr5 2,334
