Is the following behavior of the Ultimate software (firmware) a Bug or my fault?
AFAIK neither ... nor - it's the intended behavior.
The new Cura automatically connects to the printer, if it is wired via usb. And the Arduino board resets itself as soon as it detects a serial connection.
You don't need the usb connection if you print from sd card. The solution is indeed: remove the cable.
tinkergnome 927
