Suggestion on improving the draft shield - ABS no warping even on blue tape
Posted
· Suggestion on improving the draft shield - ABS no warping even on blue tape
I think your third idea has the highest chance of making it into Cura, but to be honest I expect none of these ideas will be incorporated into Cura any time soon.
I haven't seen any delamination problems in the draft shield for ABS myself, so I'll contact the materials department and see what they think.
I think a straight forward and robust approach to solving such an issue would be to make the draught shield a configurable amount of lines thick so that it's sturdier.
Thank you for reply
Yes the shield will not delaminate itself but it causes warping and peel the raft off (just like a model without the shield), very likely to happen when using an open-area printer(kossel, prusa i3 etc.) and the raft extra margin is not that wide. So what I'm doing is to force the shield to delaminate while still keep the heat inside.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
luffffy 1
Thank you for reply
