Cura running two printers at once?
billdempsey
Posted · Cura running two printers at once?
While I've never tested it, I suspect you can run two instances at once and one will connect to one printer and the other will connect to the second.
    Thanks Daid! Also, has anyone used Cura with other printers besides Ultimaker?
    Yes, quite a few actually. It works on most if not all RepRap designs if the printer runs Marlin or Sprinter.
