It's a side-effect of the "stay inside model during movement" code. Which is causing some problems with thin walls sadly.
Wouldn't it be possible to filter out these movements?
Thinking out loud: if I would make a program that reads all the gcode, and filters out sections with multiple movements without extrusion, would that be a solution?
It sounds like the new slicer that Daid and a host of others are working on will address this. ATM, Cura is limited to the capabilities of SkeinForge. I would say take a look at your part and determine which slicer you think is going to do a better job with it right now (Cura or KS) and hope the new one properly addresses the thin wall problem.
tomnagel 83
Here the printed result (left). I sliced the same block with Kisslicer (right) and there is no useless movement, and no disturbance in this area.
