How long have you waited after turning it on? It takes a while to start up and see the "Ultimaker" logo on the screen... Hopefully its just that.
If you've waited enough and still nothing happened... then contact your reseller as neotko suggests.
Thank you guys for the responses! I was going to check out the board but they have designed the compartments that house the board very well, making the screws almost impossible to access on the UM3. I sent it back and the replacement is in transit. Looking forward to finally getting it up and running!
Thanks again!
neotko 1,415
If you don't have experience checking the board cables I would contact your reseller asap so they give you help. It might be just that the cable that powers the small new board has the power cable unplugged due movement on transit.
