Well, both the drivers of the Y- and X-Axis have the voltage set to 0.5V. It seems to me that there is a problem with the Board. I'm not using the Ultiboard anymore, I've switched to RUMBA previously and with the old steppers at 1/16 stepps, it all just worked fine.
Dim3nsioneer 528
Something is broken on the Ultiboard 1.5.x, I would say. You did exactly the tests I also would have done.
Are the set currents reasonable?
