I've got a working configuration now for the Reach 3D and Cura Software. I've tested it printing via OctoPrint, and the results are as I'd expect.
The Reach 3D uses a stock Marlin firmware, so it's easy to add to Cura Software. In the "Add New Printer" machine settings dialogue, set the following options:
Maximum width (mm): 180
Maximum depth (mm): 180
Maximum height (mm): 150
Heated bed: yes (if you have that option)
Build area shape: Square
GCode Flavour: RepRap (Marlin/Sprinter)
If you've installed the E3D extruder (quite a popular option with Reach 3D owners), you'll probably want to knock the Maximum width setting down to around 170 mm. This depends on how much you had to shift the print bed to accommodate the shorter E3D extruder.
A basic draft-quality PLA ini file for Cura Software is here: R3D-Generic_PLA_for_Cura_or_OctoPrint.ini
This can also be imported into OctoPrint for use with its CuraEngine installation.
All these settings were determined empirically, and have only been tested with Cura Software and CuraEngine 15.04 under Linux. Use at your own risk.
nallath 844
It shouldn't be that hard, but I do think it's the responsibility of the people who made the printer to make a pull request for Cura to add their printers.
