"Global Link" prop reproduction (from "Earth: Final Conflict")
Shipbrook
Posted · "Global Link" prop reproduction (from "Earth: Final Conflict")
I enjoy making reproductions of sci-fi props. This one is the "Global Link" smartphone from the TV show Earth: Final Conflict (which aired a decade before the first iPhone).
With convenient belt clip!
The show had a few versions of the prop (opened to various degrees, closed, and a "hero" version which used an accordion arm and something like a miniature window roller shade to show the screen extruding from a case apparently too small to contain it). Still sourcing the parts for a hero version, but I could at least make the static versions.
Modeled in Blender, based on screenshots from episodes throughout the first season.
  • Like 3
Really cool! I understand correct that you have made 2 versions, one open and one closed?
Have you made other props too?
You should also check out our current contest in which you can win an Ultimaker 3.
It is about cosplay and prop making :)
    • 1 month later...
    WOW!
    This is fantastic!!!  Ultimaker looks like it can make really high quality models - SUPER!
    Please tell me how I could buy one of these replicas, don't worry about price.
    I look FORWARD to hearing from you.
    Sincerely
    Darren Peters
    • 4 months later...
    • 2 years later...
    You should make one in which you can insert your smartphone, so it can actually be used. With a slider system. That would be really cool.  :-)
    It might require a bit adaptation of dimensions, but as long as it is immediately recognisable...
