Hi, thank you for your post.
Could you pinpoint the layer shift on the photos where you see it?
If there is a change in surface in Z, have you tried cleaning your threaded Z-rod? You can move the bed up and down and push a cloth in between the threads. Make sure to add some new magna lube once you have cleaned it.
If you look a couple mm under the anchor holes, it looks like the layers shifted forward about a millimeter. My spidey senses say it's a loose belt, I might try printing some belt tensioners, but I don't always experience layer shift.
SandervG 1,499
