Is the format for the spool RDID tag available?
Wisar
Posted · Is the format for the spool RDID tag available?
I have the capability to write RFID tags...am I correct in assuming that is what identifies a filament spool and if so is the format available?
    As far as I know it holds a GUID that identifies the type of material. You can find the GUID's that we defined in the material .xml files that are inside Cura.
    Thanks. That is exactly what I was looking for. I am assuming that I will be able read the "format" but the coding is something else. I have my RFID reader/writer on my desk ready for a go at it this afternoon or weekend.
    -- IC INFO ------------------------------
    # IC manufacturer:
    NXP Semiconductors
    # IC type:
    NTAG216
    -- NDEF ------------------------------
    # No NDEF data storage populated:
    -- EXTRA ------------------------------
    # Memory size:
    888 bytes user memory
    * 222 pages, with 4 bytes per page
    # IC detailed information:
    Full product name: NT2H1611G0DUx
    Capacitance: 50 pF
    # Version information:
    Vendor ID: NXP
    Type: NTAG
    Subtype: 50 pF
    Major version: 1
    Minor version: V0
    Storage size: 888 bytes
    Protocol: ISO/IEC 14443-3
    # Configuration information:
    UID ASCII mirror enabled:
    * Page 0x0B, byte offset 0
    NFC counter: disabled (no tearing)
    No limit on wrong password attempts
    Strong load modulation disabled
    # Originality check:
    Signature verified with NXP public key
    -- FULL SCAN ------------------------------
    # Technologies supported:
    ISO/IEC 14443-3 (Type A) compatible
    ISO/IEC 14443-2 (Type A) compatible
    # Android technology information:
    Tag description:
    * TAG: Tech [android.nfc.tech.MifareUltralight, android.nfc.tech.NfcA, android.nfc.tech.NdefFormatable]
    * Maximum transceive length: 253 bytes
    * Default maximum transceive time-out: 618 ms
    # Detailed protocol information:
    ATQA: 0x4400
    SAK: 0x00
    # Memory content:
    [00] *  04:8F:63 60 (UID0-UID2, BCC0)
    [01] *  3A:CB:52:80 (UID3-UID6)
    [02] .  23 48 00 00 (BCC1, INT, LOCK0-LOCK1)
    [03] .  E1:10:6D:00 (OTP0-OTP3)
    [04] .  9C 15 6C 01 |..l.|
    [05] .  75 6C 74 69 |ulti|
    [06] .  6D 61 6B 65 |make|
    [07] .  72 2E 6E 6C |r.nl|
    [08] .  3A 6D 61 74 |:mat|
    [09] .  65 72 69 61 |eria|
    [0A] .  6C 31 00 00 |l1..|
    [0B] .  30 34 38 46 |048F|
    [0C] .  36 33 33 41 |633A|
    [0D] .  43 42 35 32 |CB52|
    [0E] .  38 30 41 D6 |80A.|
    [0F] .  3D B9 07 57 |=..W|
    [10] .  54 2A 3E E7 |T*>.|
    [11] .  0A 86 77 D8 |..w.|
    [12] .  4B 87 80 05 |K...|
    [13] .  E4 A1 BC 57 |...W|
    [14] .  D2 CE 00 17 |....|
    [15] .  70 6C 61 2D |pla-|
    [16] .  62 6C 61 63 |blac|
    [17] .  6B 2D 37 35 |k-75|
    [18] .  30 67 2C 31 |0g,1|
    [19] .  36 30 39 2D |609-|
    [1A] .  31 37 30 30 |1700|
    [1B] .  34 00 00 00 |4...|
    [1C] .  00 00 00 00 |....|
    [1D] .  00 00 00 00 |....|
    [1E] .  00 00 00 00 |....|
    [1F] .  00 00 00 00 |....|
    [20] .  00 00 00 00 |....|
    [21] .  00 00 00 00 |....|
    [22] .  00 00 00 00 |....|
    [23] .  00 00 00 00 |....|
    [24] .  00 00 00 00 |....|
    [25] .  00 00 11 03 |....|
    [26] .  02 53 69 67 |.Sig|
    [27] .  20 00 1C 11 | ...|
    [28] .  14 01 75 6C |..ul|
    [29] .  74 69 6D 61 |tima|
    [2A] .  6B 65 72 2E |ker.|
    [2B] .  6E 6C 3A 73 |nl:s|
    [2C] .  74 61 74 32 |tat2|
    [2D] .  00 00 02 00 |....|
    [2E] .  0B 71 B0 00 |.q..|
    [2F] .  00 00 00 00 |....|
    [30] .  00 00 00 00 |....|
    [31] .  01 B0 77 E5 |..w.|
    [32] .  5C 11 14 01 |\...|
    [33] .  75 6C 74 69 |ulti|
    [34] .  6D 61 6B 65 |make|
    [35] .  72 2E 6E 6C |r.nl|
    [36] .  3A 73 74 61 |:sta|
    [37] .  74 32 00 00 |t2..|
    [38] .  02 00 0B 71 |...q|
    [39] .  B0 00 00 00 |....|
    [3A] .  00 00 00 00 |....|
    [3B] .  00 00 01 B1 |....|
    [3C] .  20 52 00 00 | R..|
    [3D] .  00 00 00 00 |....|
    [3E] .  00 00 00 00 |....|
    [3F] .  00 00 00 00 |....|
    [40] .  00 00 00 00 |....|
    [41] .  00 00 00 00 |....|
    [42] .  00 00 00 00 |....|
    [43] .  00 00 00 00 |....|
    [44] .  00 00 00 00 |....|
    [45] .  00 00 00 00 |....|
    [46] .  00 00 00 00 |....|
    [47] .  00 00 00 00 |....|
    [48] .  00 00 00 00 |....|
    [49] .  00 00 00 00 |....|
    [4A] .  00 00 00 00 |....|
    [4B] .  00 00 00 00 |....|
    [4C] .  00 00 00 00 |....|
    [4D] .  00 00 00 00 |....|
    [4E] .  00 00 00 00 |....|
    [4F] .  00 00 00 00 |....|
    [50] .  00 00 00 00 |....|
    [51] .  00 00 00 00 |....|
    [52] .  00 00 00 00 |....|
    [53] .  00 00 00 00 |....|
    [54] .  00 00 00 00 |....|
    [55] .  00 00 00 00 |....|
    [56] .  00 00 00 00 |....|
    [57] .  00 00 00 00 |....|
    [58] .  00 00 00 00 |....|
    [59] .  00 00 00 00 |....|
    [5A] .  00 00 00 00 |....|
    [5B] .  00 00 00 00 |....|
    [5C] .  00 00 00 00 |....|
    [5D] .  00 00 00 00 |....|
    [5E] .  00 00 00 00 |....|
    [5F] .  00 00 00 00 |....|
    [60] .  00 00 00 00 |....|
    [61] .  00 00 00 00 |....|
    [62] .  00 00 00 00 |....|
    [63] .  00 00 00 00 |....|
    [64] .  00 00 00 00 |....|
    [65] .  00 00 00 00 |....|
    [66] .  00 00 00 00 |....|
    [67] .  00 00 00 00 |....|
    [68] .  00 00 00 00 |....|
    [69] .  00 00 00 00 |....|
    [6A] .  00 00 00 00 |....|
    [6B] .  00 00 00 00 |....|
    [6C] .  00 00 00 00 |....|
    [6D] .  00 00 00 00 |....|
    [6E] .  00 00 00 00 |....|
    [6F] .  00 00 00 00 |....|
    [70] .  00 00 00 00 |....|
    [71] .  00 00 00 00 |....|
    [72] .  00 00 00 00 |....|
    [73] .  00 00 00 00 |....|
    [74] .  00 00 00 00 |....|
    [75] .  00 00 00 00 |....|
    [76] .  00 00 00 00 |....|
    [77] .  00 00 00 00 |....|
    [78] .  00 00 00 00 |....|
    [79] .  00 00 00 00 |....|
    [7A] .  00 00 00 00 |....|
    [7B] .  00 00 00 00 |....|
    [7C] .  00 00 00 00 |....|
    [7D] .  00 00 00 00 |....|
    [7E] .  00 00 00 00 |....|
    [7F] .  00 00 00 00 |....|
    [80] .  00 00 00 00 |....|
    [81] .  00 00 00 00 |....|
    [82] .  00 00 00 00 |....|
    [83] .  00 00 00 00 |....|
    [84] .  00 00 00 00 |....|
    [85] .  00 00 00 00 |....|
    [86] .  00 00 00 00 |....|
    [87] .  00 00 00 00 |....|
    [88] .  00 00 00 00 |....|
    [89] .  00 00 00 00 |....|
    [8A] .  00 00 00 00 |....|
    [8B] .  00 00 00 00 |....|
    [8C] .  00 00 00 00 |....|
    [8D] .  00 00 00 00 |....|
    [8E] .  00 00 00 00 |....|
    [8F] .  00 00 00 00 |....|
    [90] .  00 00 00 00 |....|
    [91] .  00 00 00 00 |....|
    [92] .  00 00 00 00 |....|
    [93] .  00 00 00 00 |....|
    [94] .  00 00 00 00 |....|
    [95] .  00 00 00 00 |....|
    [96] .  00 00 00 00 |....|
    [97] .  00 00 00 00 |....|
    [98] .  00 00 00 00 |....|
    [99] .  00 00 00 00 |....|
    [9A] .  00 00 00 00 |....|
    [9B] .  00 00 00 00 |....|
    [9C] .  00 00 00 00 |....|
    [9D] .  00 00 00 00 |....|
    [9E] .  00 00 00 00 |....|
    [9F] .  00 00 00 00 |....|
    [A0] .  00 00 00 00 |....|
    [A1] .  00 00 00 00 |....|
    [A2] .  00 00 00 00 |....|
    [A3] .  00 00 00 00 |....|
    [A4] .  00 00 00 00 |....|
    [A5] .  00 00 00 00 |....|
    [A6] .  00 00 00 00 |....|
    [A7] .  00 00 00 00 |....|
    [A8] .  00 00 00 00 |....|
    [A9] .  00 00 00 00 |....|
    [AA] .  00 00 00 00 |....|
    [AB] .  00 00 00 00 |....|
    [AC] .  00 00 00 00 |....|
    [AD] .  00 00 00 00 |....|
    [AE] .  00 00 00 00 |....|
    [AF] .  00 00 00 00 |....|
    [B0] .  00 00 00 00 |....|
    [B1] .  00 00 00 00 |....|
    [B2] .  00 00 00 00 |....|
    [B3] .  00 00 00 00 |....|
    [B4] .  00 00 00 00 |....|
    [B5] .  00 00 00 00 |....|
    [B6] .  00 00 00 00 |....|
    [B7] .  00 00 00 00 |....|
    [B8] .  00 00 00 00 |....|
    [B9] .  00 00 00 00 |....|
    [BA] .  00 00 00 00 |....|
    [BB] .  00 00 00 00 |....|
    [BC] .  00 00 00 00 |....|
    [BD] .  00 00 00 00 |....|
    [BE] .  00 00 00 00 |....|
    [BF] .  00 00 00 00 |....|
    [C0] .  00 00 00 00 |....|
    [C1] .  00 00 00 00 |....|
    [C2] .  00 00 00 00 |....|
    [C3] .  00 00 00 00 |....|
    [C4] .  00 00 00 00 |....|
    [C5] .  00 00 00 00 |....|
    [C6] .  00 00 00 00 |....|
    [C7] .  00 00 00 00 |....|
    [C8] .  00 00 00 00 |....|
    [C9] .  00 00 00 00 |....|
    [CA] .  00 00 00 00 |....|
    [CB] .  00 00 00 00 |....|
    [CC] .  00 00 00 00 |....|
    [CD] .  00 00 00 00 |....|
    [CE] .  00 00 00 00 |....|
    [CF] .  00 00 00 00 |....|
    [D0] .  00 00 00 00 |....|
    [D1] .  00 00 00 00 |....|
    [D2] .  00 00 00 00 |....|
    [D3] .  00 00 00 00 |....|
    [D4] .  00 00 00 00 |....|
    [D5] .  00 00 00 00 |....|
    [D6] .  00 00 00 00 |....|
    [D7] .  00 00 00 00 |....|
    [D8] .  00 00 00 00 |....|
    [D9] .  00 00 00 00 |....|
    [DA] .  00 00 00 00 |....|
    [DB] .  00 00 00 00 |....|
    [DC] .  00 00 00 00 |....|
    [DD] .  00 00 00 00 |....|
    [DE] .  00 00 00 00 |....|
    [DF] .  00 00 00 00 |....|
    [E0] .  00 00 00 00 |....|
    [E1] .  00 00 00 00 |....|
    [E2] .  00 00 00 BD (LOCK2-LOCK4, CHK)
    [E3] .  40 00 0B FF (CFG, MIRROR, AUTH0)
    [E4] .  00 00 -- -- (ACCESS)
    [E5] +P XX XX XX XX (PWD0-PWD3)
    [E6] +P XX XX -- -- (PACK0-PACK1)
      *:locked & blocked, x:locked,
      +:blocked, .:un(b)locked, ?:unknown
      r:readable (write-protected),
      p:password protected, -:write-only
      P:password protected write-only
    22 hours ago, mike_create said:
    Has anyone had success in writing back a .xml file to the NFC tags?
    Mike
    You can't. They don't have enough room to store the entire xml file. They just hold an identifier (the GUID) that links them with an xml profile.
        • 30 replies
