Cura 2.3.X for UM3 - Aligning multi-material prints for dual extruder
Mcribwich
Posted · Cura 2.3.X for UM3 - Aligning multi-material prints for dual extruder
Howdy!
I've been trying to merge two stl files imported into Cura into a single multi-material part. The 2 stl files are split bodies from a single multi-body part designed in Solidworks. From what I've read in many many posts, Cura should be aligning the origins of these two bodies (and because they are from the same part, the origins should be the same). However, I find that after merging there is a slight (~1mm) offset in a couple planes when merged.
The one way they seem to align properly is if I select "Do not translate STL output data to a positive space" option when exporting the STLs (see attached image).
Was just wondering if anyone else has tips/tricks for ensuring your part origins align?
Thanks!
    Posted (edited) · Cura 2.3.X for UM3 - Aligning multi-material prints for dual extruder
    Cura should merge them using the offset as they where designed (afaik). I don't know solidworks so I can't help there.
    If the misalignment is visible and you know by how much you could Ctrl Click the part merged and move it using the move button to do It using numbers or a less precise move with your mouse.
